lifting a C2 - NCRS Discussion Boards
lifting a C2
  • John Pickens
    lifting a C2
    I am aware of the recommended sites for jacking up a 65. Is there any reason
    not to jack the front end by placing the jack beneath the frame directly under
    the engine block?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: lifting a C2
    You could bend/distort the formed crossmember depending on what you are using to lift at this portion of the frame. I have lifted my 68 and 70 in this area with my floor jack and use a large piece of 2/6 to spread the load. Using a lifting device with a small contact point could very well change the shape of the crossmember. Using the four lift points in the service manual are really the best to stay with.
