67 BB Hood Information - NCRS Discussion Boards
  • Wayne W.
    • April 30, 1982
    • 3605
    Does anyone out there have a NOS over the counter 67 BB hood? I would like to determine a couple of details. Does anyone out there have a 67 BB hood that has provisions for the hood support on both sides? Will everyone out there that has an original 67 BB look at them and tell me if it has a small hole for a push in fastener in the end of the rear ledge weatherstrip. Thanks.
  • Mike McKown
    Re: 67 BB Hood Information
    Wayne:
    I have a '67 BB hood. I've owned it since '78 and it wasn't new then. If this qualifies as an original then here we go:
    The hood has push pin holes for the weatherstrip centered just about on the male latch pin.
    The hood inner panel has two holes on the left side with a threaded reinforcement plate riveted to the innner for the hood support. The right side has the holes in the inner panel but no reinforcement plate to attach the support to.
    • Dave Stafford
      Wayne, I have an early '67 car, original hood, and no provision for hood support other than driver-side. I can see no pin hole, but with so much glue, there is no way to tell .
      Hope this helps
      Dave
      • Wayne W.
        • April 30, 1982
        • 3605
        Thanks, David
        The hole should be where the weatherstrip ends. There was a push in rivet in the end of the weatherstrip. I do not know if early cars had this feature.
