C1 master cylinder - NCRS Discussion Boards
C1 master cylinder
  • Joe Pennington
    C1 master cylinder
    My 56 has a replacement Wagner Master cylinder that I'm replacing. I believe the 58-62 master cyl # is 6456022 but not sure on the 56/57. I have a 6450233 unit- do I have the correct number? Thanks, joe
  • Donald L.
    • September 30, 1998
    • 461
    Re: C1 master cylinder
    According to the Judging Manuel the Part # is 5454480 and the casting # 5450233 .
    Donald 331176
    • Joe Pennington
      Thanks for checking Donald. I rechecked the casting # on the unit I have and it starts with a 6, not a 5. I wonder what it application was?
      • Bernard M.
        • August 31, 1994
        • 341
        Joe, If you'll post the PART NUMBER, I may be able to find the original application for you if it makes a difference. The part number is stamped in the plug on the forward end of the master cylinder. The casting was used for several different applications (notably Buicks) so the casting number alone will not tell the whole story. If you are attempting to replace it with an original, use the stamped part number in combination with the casting number to determine if it's the correct part. Bernie Myers
        • Joe Pennington
          Benard, The part number is 5454350 on top and 320 under.
          Thanks, Joe
          • Bernard M.
            • August 31, 1994
            • 341
            Joe, It started life on a 1954 or 1955 Buick with manual brakes. There is likely a casting date on it (L/H outboard toward front) that will give a good indication of which model year.
            • Joe Pennington
              Thanks for the help. The unit is dated 1955. I need to replace the Wagner I have, so I'll go ahead and use the Buick since it's been rebuilt, until I can latch on the correct one at a fair price. Joe
