C2 L79 LH Vertical Igntion Shield for PB - NCRS Discussion Boards
  • Jimmy B.
    • July 31, 1980
    • 584
    Can someone send me a pic of the LH Vertical Ignition shield for a small block with power brakes so I can make sure I don't acquire the incorrect piece for my car? Thanks.
    • 43238
    Re: C2 L79 LH Vertical Igntion Shield for PB
    Jimmy-----
    I'm not aware of any difference between the left half vertical shields for cars with and without power brakes.
    • Jimmy B.
      • July 31, 1980
      • 584
      Joe,
      I understand the LH vertical with power brakes has a pronounced dip inward to clear the booster but I would like a picture of a regular one and one with the dip since I have a chance to purchase one to make sure I get the correct one.
      Thanks.....Jim
      • Paul L.
        • November 1, 2002
        • 1414
        Here is a pic of mine. I do not have a non-PB car with which to make a comparison, however.
          Nope - there was only one L.H. vertical ignition shield, used on all cars whether they had power brakes or not.
          • Paul L.
            • November 1, 2002
            • 1414
            Another View
            • Jimmy B.
              • July 31, 1980
              • 584
              Re: Another View
              Thanks Paul for the pic's. I appreciate it.
                • 43238
                Paul------
                I believe that the configuration of the left side vertical shield seen for your car is the same for all 64-67 Corvettes. Although some additional clearance is necessary for the power brake booster, this was designed into the part used for all cars. When you think about it, why would GM have used (and had manufactured)different shields for cars with power brakes and non-power brakes? Certainly, the shield for power brake cars would work on non-power brake cars and who would know the difference? The same thing was true for big block valve covers. All cars got the left side cover for the power brake booster relief whether or not they had power brakes.
                • Paul L.
                  • November 1, 2002
                  • 1414
                  Joe,
                  I agree with you completely. BTW I have had a great deal of enjoyment from the 1967 this summer. A real fun car even with the PowerGlide. My 1979 L-82 was a nice car but this one is just a real treat!
