'53 vacuum lines - NCRS Discussion Boards
'53 vacuum lines
  • Gordon A.
    • April 30, 1991
    • 30
    '53 vacuum lines
    I am looking for a source for the steel vacuum lines for '53 six cylinder. I was told a company called "The Right Stuff" reproduces them, but I can't find them. Any ideas? Thanks very much
    Gordon Andrus
    Houston Corvette Service, Inc.
    713-896-0119
  • Mike M.
    • May 31, 1974
    • 8396
    Re: '53 vacuum lines
    Did you try Classic tube and performance at 800 tubes-1-. they made up a set of gas/brake/ vac. lines for our 39 chevy woody which is probably in less demand than the 53-55 vets. jack Reeves at 5362 Corvgette Place(formerly john rorhner co) at 336 852 1011 should also have them. You could also make up the lines--check out a 53-4 on a ncrs judging field to get an idea of the shapes and get a tubing bender. good luck, mike
