Re: '63 Muncie Bearing Retainer - NCRS Discussion Boards
  • Douglas Cline
    Hi,
    I just picked up a '63 Muncie Bearing Retainer to fit
    a 421 63 Bellhousing. The part is cast iron with part
    number 358475 GM 1 cast into the front of the retainer.
    The diameter of the retainer is 4-1/8", which seems correct
    for the 421 bellhousing. I was wondering if anyone could verify
    the part number.
    --Doug, # 13644
    • 43238
    Doug-----
    GM #358475 was the casting number used for retainer GM PART #358474. It was discontinued in July, 1983 and replaced by GM PART #14038689. Neither the GM #358474 or the 14038689 have any Corvette application that I can find. They did have some other Chevrolet and Pontiac applications, but I can't determine specifically what they are.
    It's also POSSIBLE that other bearing retainers were manufactured from the GM #358475 CASTING. I can't confirm that, though. Also, I believe that GM SERVICE bearing retainers sold after about 1965 under GM PART #604932 for the 63 application may have been made of cast iron as opposed to the original aluminum. I'm not sure of this, though, and, in any event, I don't know what casting number that these units carried.
    The 63-only retainer had an OD of 4-3/16".
    • Clem Z.
      • January 1, 2006
      • 9427
      from my sperence you are better off with a cast iron one rather than a aluminum one because the aluminum ones had a problem with getting worn or rought from the dirt and grease and causing the TO bearing to stick.
      • Loren L.
        • April 30, 1976
        • 4104
        The one I have in the garage carries
        a 604932 casting, FWIW
          • 43238
          Re: The one I have in the garage carries
          Loren-----
          Is the piece that you have cast iron or aluminum?
          • Robert L.
            • March 31, 1975
            • 6
            Ditto on the '63 Muncie front retainer: 604932 (Cast Iron)
            Bob L.
            • Douglas Cline
              Re: '63 Muncie Bearing Retainer - Thanks
              Thanks for the responses. I have re-measured the diameter
              and it is in fact 4-3/16".
              Thanks for your help!
