58 T-10 gear parts, manual - NCRS Discussion Boards
  • Randy M.
    • July 31, 1998
    • 38
    ANyone know a supplier for gear parts and a rebuild shop manual for 58 T-10?
    THanks
    • 43222
    Re: 58 T-10 gear parts, manual
    Randy-----
    The rebuild procedure should be covered in the 1958 Chevrolet Chassis Service Manual. Also, any manual covering the rebuilding of Borg Warner T-10s should provide you with most, if not all, of the information which you need to overhaul the transmission.
    For parts, check with Ed Hartnett of Lansdowne, PA at 610-623-9381.
    • Tom P.
      • April 1, 1980
      • 1815
      Larry Fischer of D and L Transmission is as good as they come, 631-351-4837.
      • David Bodily
        Tom,
        Here is a link to a PDF file for a rebuild manual. It is for the St-10 but the procedures are the same very few parts difference. http://fiedlerh.home.att.net/images/ST10man.pdf
        • David Bodily
          Sorry I ment Randy
