Yet another 1969 AIM question...again... - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1588
    Morning all,
    I cannot read the following page:
    UPC: LT1
    Sheet: A1
    Title: V-8 Eng. 350 CU. IN. Spec. Hi Perf - Contents - Gas Pipes & Fuel Pump
    Items: 1, 2, 3, 4, 6, 7, 8, 9 & 10
    I can read items 5, 11, & 12
    TIA, Don
  • Donald O.
    • May 31, 1990
    • 1588
    Re: Yet another 1969 AIM question...again...
    Its the part numbers I can't read
    Don
      • 43221
      Don------
      1= 3886152
      2= 3959442
      3= 3858533
      4= 446212
      6= part deleted; was 9425643
      7= part deleted; was 138494
      8= part deleted; was 3739422
      9= 6440709
      10= 3886153
        • 15601
        Re: Yet another 1969 AIM question...again... *TL*
        #1 3886152 - Pipe Asm.
        #2 3959442 Pipe Asm.
        #3 3858533 - Pulley
        #4 446212 - Washer
        #5 181629 - Bolt
        #6 removed 3-19-69, was 9428643 - Bolt
        #7 removed 3-19-69, was 138494 - L. Washer
        #8 removed 3-19-69, was 3739422 - Washer
        #9 6440709 - Pump Asm. - Fuel
        #10 3886153 - Tee
        #11 - 3959444 Bracket
        #12 - 187875 Screw
        You are getting close to the end Don.
        • Donald O.
          • May 31, 1990
          • 1588
          Thanks gents *NM*
