plug wires - NCRS Discussion Boards
plug wires
  • Rick Hendel
    plug wires
    I have a 1966 corvette that has a rough idle and a back firing problem for only the first 3-4 minutes when the car is started. I have replaced everything but plug wires. It possible for a plug wire to perform poorly only when the engine is cold. Thanks
    Re: plug wires
    Rick -
    Sounds more like a choke adjustment issue than plug wires; if the choke setting is too lean, it will produce the symptoms you describe.
