transmission linkage for a '57 - NCRS Discussion Boards
  • Mike Noguera
    Hi- I'm having a problem purchasing the transmission linkage for a '57 powerglide.
    After waiting 4 weeks, "Dr. Rebuild" can't get one either!!!
    It seems that no one is reproducing it anymore.
    I've tried quite a few vendors with no results-
    Any suggestions???
    Thank you in advance,
    Mike
  • Dave Christensen
    Re: transmission linkage for a '57
    Did you try Mary Jo @ (858) 451-1933? She usually has stuff like that.
    Which linkage do you need? The linkage to the shifter or the one to the carb kickdown?
    As I remember the shift linkage is just a rod, threaded on the ends, with a clevice on both ends. You could make one or have one made fairly easily. I could probably make a drawing of mine if you need to have one made.
    You can make the kickdown linkage from a car or pickup work on the Corvette. Modifications will depend on the intake manifold that you have - FI, 1X4, or 2X4.
    good luck,
    Dave Christensen
    • Mike Noguera
      Hi Dave- thanks for the offer.
      I purchased the "kickdown" for my 1X4 setup.
      I need the linkage that goes from the shifter to the transmission.
      I need the exact dimensions & a drawing would be great!!!
      YES, I tried MaryJO over a year ago when I purchased the shifter from her & she still can't get one. Corvette Central and Dr. Rebuild also show it on their catalog- I bought one only to wait for weeks empty handed.
      I'm either going to have to find a used one BUT I think I'll have better luck making my own!!
      My email address is : Pats57@cs.com (my wife's name is Patti and my lic# is PATI'S 57) that's the reason for the email address!!!
      • Mike Noguera
