1972 Corvette LS5 plug fouling question - NCRS Discussion Boards
  • Jon Foster
    Just got my LS5 engine rebuilt to stock specs except for a bump in compression to 9.5-1. Stock cam, carb, everything. 50 test miles on engine and I have fouled the #6 plug twice. Not fuel or oil fouled but black carbon. Other plugs are lightly carboned. I have AC 44t plugs in along with a new cap, rotor, points, wires and condensor. Are the plugs to cold? ANY suggestions? THanks, John
  • Dave S.
    • August 31, 1992
    • 2926
    Re: 1972 Corvette LS5 plug fouling question
    Jon,
    I'd try an R45TS which is hotter and has an extended tip(S). There is a good chance that it will solve your problem.
    • Clem Z.
      • January 1, 2006
      • 9427
      make sure the plug wire is all the way into the distributor cap and also check it with a ohm meter to make sure that the wire is good.
