Help on '82 Engine - NCRS Discussion Boards
Help on '82 Engine
  • Mike R.
    • May 31, 2002
    • 119
    Help on '82 Engine
    Does anyone know if the 82 engine is supposed to have two (RF and LR) spark plug heat shileds or four, one at each position? Thanks
    Mike Robb
  • John Wissocki
    Re: Help on '82 Engine
    Mike, I have a 1982 Collector Edition, it only has 11,000 orig. miles on it. It is 100 % original except for the engine oil. There is only an ignition shield on the left rear and right front. Have you had any problems with you CrossFire?
