expansion tank-427/425? - NCRS Discussion Boards
  • Michael F.
    • 745
    Does the 66 427/425 have an expansion tank? Also is the themostat housing alum or iron and what is the number on it? Thanks.
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
  • Peter M.
    • February 1, 1984
    • 361
    Re: expansion tank-427/425?
    No expansion tank. Therm housing is GM#3877660
    • Michael F.
      • 745
      Thanks Peter, you confirmed what I suspected.
      Michael
      • Craig S.
        • June 30, 1997
        • 2471
        Michael - also, your radiator should be copper/brass with integral cap, the expansion tanks were only used with the aluminum radiators...Craig
        • William V.
          • December 1, 1988
          • 399
          The 65 396 & the 67-L88 were the only c2 big blocks with aluminum rad & expansion tank
            • 43222
            Craig------
            Not quite. All 1969-72 big blocks with copper-brass and aluminum radiators used an external supply tank. For all without A/C, the supply tank was the same one used for small blocks with aluminum raidators. For big blocks with A/C, a cylindrical brass tank was used.
            • Craig S.
              • June 30, 1997
              • 2471
              Joe - thanks for the clarification, my mind is usually in the midyears...didn't mean to misconvey information and I learned more!...Craig
