C2 rear spring _ dead horse - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    In light of recen posts on the subject, I'm sorry for flogging the horse, but I want to make sure I understand.
    The instructions in my 63 shop manual (section 4-8)for installation of the rear spring are 1) place spring on carrier cover mounting surface..... 2) place center clamp plate in position, install bolts, torque to 55-75 lb. ft. 3) raise spring outer end with floor jack......
    Does this procedure risk breaking the ears off of the differential cover?
    Steve
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C2 rear spring _ dead horse
    Yes. Do not tighten the bracket bolts until the outer bolts are installed.
    • Steve D.
      • February 1, 2002
      • 990
      Thanks *NM*
