61 Parking brake alarm actuating switch - NCRS Discussion Boards
  • Bruce G.
    • December 1, 2002
    • 36
    Just got back from Carlisle. I did great with my shopping list, but two items seemed impossible to find. Anybody got some ideas? The '61 parking brake alarm whereby a #257 bulb flashes after a short time with key on requires bracket, brown wiring& plug, bulb and actuating switch. The actuating switch nobody has and most say will be impossible to find. All big vendors said "good luck" and be ready to spend big time if you can find one ( so what's new!). Some one said I could probably get a '64 type switch and rig it to work with wiring setup I got from Lectric limited. Yes???? No??? Also I could not find info on battery warranty and warranty booklet needed in Seat separator compartment packet. The owners guide,radio instructions,clock instructions and gray owners envelope are readily found in Corv.Central etc. Thanks for assistance.. Bruce #39024
  • Mike M.
    • May 31, 1974
    • 8396
    Re: 61 Parking brake alarm actuating switch
    good luck on e-brake needs but M.F. Dobbins, the decal fella out of the philadelphia area, may have the paperwork you're needing. think he ads in hemmings and driveline. certain he vendors at carlisle. mike
    • Dennis A.
      • April 30, 1999
      • 1010
      Bruce...
      Try Mary Jo's, I believe she has a limited supply of original emergency brake light switches. #257 Bulbs are available.
