C1 - VIN Tag - NCRS Discussion Boards
C1 - VIN Tag
  • Jim K.
    • August 31, 2000
    • 554
    C1 - VIN Tag
    I did some work on my steering box over this past spring and knocked off the VIN tag. Any hints as to how to re-attach it. I know I could glue/epoxy/silicon it back on, but I would rather it be more permanent and original looking. Has anyone had any luck trying to spot weld it, and what EXACTLY did you do? Thanks in advance!!!
    On a side note, I went to Carlisle for the first time, and I still can't believe how many cars and people selling parts were there. Had a great time!!!
  • Mike M.
    • May 31, 1974
    • 8385
    Re: C1 - VIN Tag
    Jim: unless your welding expertise is exceptional, i wouldn't try spot welding the vin tag back on the steering col. I'd silicone or epoxy it on THEN take a wire tie(that can easily be removed during judging events if that is what you aiming for) to retain the vin tag in the event the silicone or epoxy fails. a Wire tie won't fail--better yet, use 2 wire ties.Mike
    • Mike M.
      • May 31, 1974
      • 8385
      Re: C1 - VIN Tag
      P.S. I use the wire ties on our c-1s that have intact spot welds as a precaution. mike
      • Christopher R.
        • March 31, 1975
        • 1599
        Re: C1 - VIN Tag
        I don't even trust wire ties. I use a hose clamp. Now I'm thinking about 2 hose clamps.
        • Jim K.
          • August 31, 2000
          • 554
          Re: C1 - VIN Tag
          Thanks for the info, but can anyone help me with the welding data so I can show it to a welding friend of mine??? (I'll doe the hose clamp trick too!)
