What I'm doing is such a simple procedure that my problem has become ridiculous for me.
I replaced the valve cover gaskets on my 68 big block and the one on the right side keeps developing a leak around the middle lower two bolts (above the exhaust manifold). After tightening them down, to no avail, I've taken the cover off and found the gasket around these two bolts smashed to "Smitherenes".
I tried it again, (Twice, with 2 new gaskets!) adjusting my procedure to "not as tight" and even a uniform, cris-cross tightening pattern (At that point who knows what would work). Both times smashed and leaking. While I'm waiting for some new and correct gaskets to arrive, tell me WHAT is it that I'm doing, not doing, or need to try? Thanks in advance. Tom
