I am restauring a 63 SWC Fuelie. My engine builder is rebuilding my engine.He was highly recomended as being an expert engine builder. The shortblock came out of an originally hi-perf. block, being build to fuelie specs now. My engine builder suggested to use a cast iron 350 CI solid lifter crank, inplace of a forged 327 CI crank, as was used originally. He said, that because we are going to use lower compression pistons, in order to burn pump gas,this change in crank style would offset any HP drop due to the lower compression ratio (9.5:1). I am going to use a new 097 cam, also known as a 30/30 Duntov cam. Any comments ? Am I doing the right thing ? I want to use the car as a driver, after judging.
Rainer
Rainer
