Need a little help
I am planning to replace my radiator shroud on my 66 small block with AC. It appears removing the fan/clutch assy and upper radiator hose will not be sufficient to remove existing shroud. Will I have to remove or loosen the radiator support and radiator and open up some fittings my AC system? On my 66 2 refrigerant lines run thru the radiator support and connect to the condenser and drier which are mounted on the radiator support. If I have to open the AC system I'll defer this project to a later time.
Anybody been there done that?
