I am getting leaking form you vapor line on the right sid of the tank. The drip happen when the car is running. It seem like quit a bit of gass, not a stream but a good dripp. I have a rubber hose going from the tank to the steel line on the frame. The leak is happening at the conection of the hose to the line. Two question; what could cause the drip? and is it suppose to be a rubber hose from the tank to the line?
Thank you,
Brandon
PS Assembly manual on the way. Should help out with some of this " is the set up correctly" stuff. I just want to get this solved soon seeing that the drip is right above my exhaust pipe
Thank you,
Brandon
