What is the best way to replace the crossed-flag emblems on my '66 spinners? I removed the spinner from the wheel cover and the old emblem looks to be rivited to the inside of the spinner. I assume removal is done by drilling out the rivits, but how is a new emblem attached?
'66 Spinner Emblem Replacement
Re: '66 Spinner Emblem Replacement
I have done this. If you look at the new ones, you see that they have "ears" that snap over the posts that look like rivets. Unless someone has done something else, you should be able to pry (or push from the front) the old one off and snap the new one on. After that I put a drop of Duco cement on each of the attach points.
Good luck
Rich Giannotti1966 L79 Convertible. Milano Maroon
1963 Corvair Monza Convertible- Top
