C3 Electrical Question - NCRS Discussion Boards
  • don justham
    In the center back stowage compartment of my 1970 convertible there are two female plugs. One is attached to a wire lead that looks like it may be a ground and the other is empty. What should be plugged into it. Is it for a light? Thanks for the help. I could not find it in the Assembly Manual.
  • Jim T.
    • March 1, 1993
    • 5351
    Re: C3 Electrical Question
    The wires could very well be for your center stowage compartment light. Some owners disconnected this light because the compartment light would stay on even though the door was closed and run down the battery.
    • Dick W.
      • 10483
      The center storage box should have a light. GM service replacement boxes (when they were still availabe) did not come with the lens cover. This is why you do not see indications of a lamp. Reproduction boxes come with the lens attached. Switches/lamp socket are available also from repro suppliers
      Dick Whittington
        Hey, Dick, welcome back!
        A little add-on here. Because the center storage compartment liner was non-conductive, flocked, fibre board its glove box light needed two wires (power and return ground). Why they opted to build the harness with two separate in-line connectors instead of a single, dual terminal, connector remains a mystery to me....
