C2 rear spindle removal - NCRS Discussion Boards
  • Eugene B.
    • May 31, 1988
    • 710
    Members,
    Is a Drive Spindle Removal Tool such a J-8433 the best/only way to remove the rear drive spindles from the support?
    A block of wood and my favorite hammer failed to accomplish the task.
    Gene
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C2 rear spindle removal
    Its not the only way, but it works. Make sure to keep it tight.
    • Don H.
      • December 1, 1981
      • 1487
      I have used various methods including a home made assembly and a tool that I believe works like the tool you listed (bolts to the strut and caliper mounts). It all depends on how hard it comes out. I had one that we had the trailing arm in a press and it still would not come out. That one we had to cut the bearing with a torch. The tool works well if it isn't too tight. Don H.
      • Werner R.
        • March 3, 2008
        • 184
        if you can borrow a two handed slide hammer, it works great. mine came off after 33 hits ie about 5 minutes. easy to install. when i had to remove spindle again a few days later for a final adjustment, it took 5 hits.
        • Eugene B.
          • May 31, 1988
          • 710
          Werner,
          Thank you for your response and tip about the slide hammer puller. I have one with an attachment to bolt to the wheels studs. Question is: How will I hold the trailing arm assembly? It is currently off the car. I'm a little concerned about locking the pivot point in a vice and banging away. Sounds like I could bend the trailing arm?
          Gene
          • Don H.
            • December 1, 1981
            • 1487
            Gene,
            If the trailing arm is off, take it to a machine shop and have it pressed off. Would be well worth the minor cost. Don H.
            • Craig S.
              • June 30, 1997
              • 2471
              Gene - I used a slide hammer in the old days. One came off on my 74, the other I wore my arms out...and it didn't budge. If your arms are off, do the press operation as Don suggests..Craig
              • Werner R.
                • March 3, 2008
                • 184
                sorry, i overlooked the part about the arm being off of the car. take it to a shop with a press.
                werner
