C2- 1967 - 3810 Carb base gaskets - NCRS Discussion Boards
  • Glenn Ochs
    I am having trouble locating the 3-part base gasket set for the Holley 3810 carb on a 67 327-300 coupe I have. Can anyone point me to a supplier that has the two gaskets and the heat sheild available as a kit?? Or what part numbers may be if they are still available OEM? Thank you in advance for your input and assistance.
  • Mike M.
    • May 31, 1974
    • 8389
    Re: C2- 1967 - 3810 Carb base gaskets
    Glen: Long island corvette shows the pieces in their catalog. good luck, mike
    • Mark G.
      • March 1, 2001
      • 227
      • Craig S.
        • June 30, 1997
        • 2471
        Also Doc Rebuild has these gaskets as I recall...Craig
          • 43221
          Mark-----
          Absolutely correct. Originally, only a gasket and the stainless steel heat shield were used. The gasket goes on the manifold first, then the shield, then the carburetor. What happens is that some folks just can't accept that "it's supposed to be that way". So, they ADD a gasket between the shield and the carb. That's likely how Glenn's car may have wound up with gaskets "sandwiching" the shield.
          The same scenario "plays out" with all 68-69 Corvette Q-Jet applications which use the same sort of shield and gasket installation.
          • Ronnie Robertson # 36786
            Glenn,
            Carquest has (or can get) all the gaskets and heat shield you need at reasonable prices.
            • Jean C.
              • June 30, 2003
              • 688
              Joe et al,
              What is the sequence for installing gasket(s), spacer and stainless blocker on a '64 300 hp with AFB carb?
              Charlie
                Charlie -
                Don't have a '64 A.I.M., but on a '65 L-75 with an AFB, it's manifold, gasket, insulator, (metal) baffle, and carb.
                • Brian Monticello
                  Re: C2- 1965 - 2818 Carb base gaskets
                  Was there a baffle on the '65 350 and 365 HP motors with the Holley 2818? Can't seem to find a replacement in any catalogs so I'm guessing NO. Is there only a the base gaslet between manifold and carb?
                  brian
                    I'm pretty sure there was no "baffle" required with the aluminum intake/Holley combination, as there was no crossover heat passage up to the carb mounting pad on the aluminum intakes for the L-79 and L-76, unlike the iron manifolds with AFB's that DID have heat up there and required baffles. The L-76 section in the '65 A.I.M shows only a gasket.
                    • DarenSchneider
                      I have a bone stock 67 L-79 in which I experience gas boiling out of carb. I have purchased a 70 LT-1 heat spacer/shield and custom fabricated it to fit my stock 67. What should that sequence be. As the manifold has 2 small holes and 1 oval hole, should I go square gasket all the way, or start the the matching manifold gasket.
                        Darren -
                        I have a GM #3969835 aluminum carb heat shield hanging on the wall (I think it was a field TSB part for fuel percolating on an '82 or '83 Z/28), and both the shield and attached gasket have a big square opening.
