C2 Idler Arm Questions - NCRS Discussion Boards
  • Mike S.
    • September 30, 1999
    • 91
    I often see idler arms included in C2 front end rebuild kits. Do idler arms actually "wear out" or do they simply have bushings/bearings/whatever that need replacement? Is rebuilding a realistic option or is replacement of the entire idler arm a more practical approach?
    Thanks as always,
    Mike S
    #33053
    • 43203
    Re: C2 Idler Arm Questions
    Mike-----
    Idler arms DO wear out and, given their importance in the whole steering equation, even a slight amount of wear to the internals renders the arm unsatisfactory.
    The design of all stock GM-type and most aftermarket arms is such that rebuilding is not possible in any practical sense of the term. Plus, no internal parts are sold to service the idler arms.
    • Mike S.
      • 91
      Thanks Joe! *NM*
      • Mike M.
        • May 31, 1974
        • 8377
        Re: Thanks Joe!
        Agree with joe but if you're gonna have it judged, get an idler arm without a grease fitting or "loose" the drilled and tapped hole in the bottom face of the arm as judges deduct for non-original zerk fittings. mike
