1970 LT-1 Choke coil & Stuff - NCRS Discussion Boards
  • Jeremy D.
    • November 1, 1998
    • 323
    Can anybody tell me the GM part numbers for a 1970 LT-1 choke coil, rod, coil cover, rod, and rod clip? I've seen the rod, clip, etc. at Paragon, Zip, etc. but I'd like to at least have an NOS cover, rod & clip. Does GM still make the coil(I doubt?) I've been trying to find these numbers and I haven't had any luck. Thanks In Advance!
    • 43221
    Re: 1970 LT-1 Choke coil & Stuff
    Jeremy------
    The parts are as follows:
    thermostat (coil)----GM #3887148-----still available from GM
    thermostat cover-----GM #3864866------still available from GM
    choke rod w/o EEC----GM #3970080------discontinued
    choke rod w/EEC------GM #3970084------discontinued
    rod clip-------------GM #7003137------discontinued
    • Jeremy D.
      • November 1, 1998
      • 323
      Thank You Very Much, Sir!! *NM*
      • Sal C.
        • December 1, 1984
        • 430
        Re: Thank You Very Much, Sir!!
        The current version of the cover from GM is different from what originally came on your LT1. Your better off having an original re-plated.
