C3 auto trans - NCRS Discussion Boards
C3 auto trans
  • Andrew Strauss
    C3 auto trans
    I just did a test drive after rebuilding my trans in my 70 bb.The trans struggled to shift from 1-2 and never shifted to 3rd,I found the vaccum tubing for the shift modulator is splitt and therefore was only getting 7in lbs.How much vac is needed for proper shifting?
    Re: C3 auto trans
    Full manifold vacuum - the trans senses engine load conditions based on the level of manifold vacuum fed to the modulator; if it's seeing less than actual full manifold vacuum, it's being "fooled" and won't shift properly.
