C1 oil filter cannister - NCRS Discussion Boards
  • Jon S.
    • November 1, 1992
    • 202
    I finally found a 6 3/4 oil filter cannister at the local bone yard. I found it on a chevelle. When looking at the internal structure there is a bell-shaped sheet metal retainer rather than a washer to push the filter up. The spring is crimped on the filter side of the metal retainer that holds everything in place. Is this correct for my 62? I assume it will work. At least the bolt doesn't fall out. Thanks in advance!
    Best regards, Jon
  • mikemccagh
    Re: C1 oil filter cannister
    what you got at the bone yard is what you need .mikie
    • Jon S.
      • November 1, 1992
      • 202
      Thanks Mike *NM*
