Yet Another 1969 AIM Question - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1588
    UPC: 1Doors
    Sheet: K7
    Item: 1
    Part #: ?
    Part Name: Upper Hinge Asm L&R
    Title: Side Door Hinge
    I can't read the part numbers
    Again,TIA
    Don
    • 43221
    Re: Yet Another 1969 AIM Question
    Don-----
    The part numbers for item 1 are 3976361-2. However, this was a late 1969 part change that, according to the revision block, was dated 7-29-69. The previous part numbers were 3935609-10. So, depending upon which revision of the AIM that your copy was made from, you may have the latter numbers showing for item 1. Check your revision block.
    • Donald O.
      • May 31, 1990
      • 1588
      Thanks Joe.
      The revision block shows the superceded p/n but I could not read the final p/n at the top of the page.
      Don
