65 396 oil cap configuration - NCRS Discussion Boards
  • Daniel K.
    • April 1, 2002
    • 190
    I would like to get some input on the "correct" oil cap for the 65BB engine. I have been told the 65 396 oil caps were not plated and not painted / blackened or darkened either. The original un-plated S oil cap also should have the rivet upside down (the S rivet head facing towards the head and the stacked dimple towards the air cleaner). Can anyone confirm the configuration of the original oil cap? Thanks again for your help. Dan K.
    • 43238
    Re: 65 396 oil cap configuration
    Dan-----
    The 1965 L-78 oil caps were finished with a black enamel paint that sometimes appeared to have a greenish hue. There was a round headed rivet in the center of the cap which contained the embossed "S" for Stant Manufacturing.
    • Craig S.
      • June 30, 1997
      • 2471
      I also recall from a parts originality class in Bloomington this year that the peened end has a deep dimple in the center, whereas the repro doesn't...Craig
      • Daniel K.
        • April 1, 2002
        • 190
        Joe and Craig,
        Thanks for answing the question on the oil cap. Your time is appreciated. Dan K.
        • Bill W.
          • March 1, 1980
          • 2000
          My orig. from #16120 is low grade gloss black enamel, no green hue, has the s stamp with a square deep dimple rivit in the inside center.it also has a small (1/4) SM in a double circle in the sheet metal center flat section next to the rivet.Bill
          • Bill W.
            • March 1, 1980
            • 2000
            sorry I forgot the round s side of the rivet faces up tward th air cleaner.
            • Daniel K.
              • April 1, 2002
              • 190
              Thanks Bill. I appreciate you sending me this information. Dan K.
