C2 1963 Fuelie distributor cap - NCRS Discussion Boards
  • Jerry S.
    • May 31, 2003
    • 145
    Does this car require a special distributor cap to be considered correct?
  • mikemccagh
    Re: C2 1963 Fuelie distributor cap
    C-2 fi dist caps have towers shorter than their Carb'd brothers as the carb dist cap on a fi dist will interfere with ing shield. i'm told 60 olds 394 ci dists used same cap as fi vets 63-65. mike
    • William C.
      • May 31, 1975
      • 6037
      D-310 (no "R") cap Delco Remy
      Bill Clupper #618
        • 43208
        Mike----
        Yes, ALL 1959-63 Oldsmobiles as well as 1964 Oldsmobiles with 394 engine used the Delco D-310, GM #1943047 distributor cap, the same one used for 63-65 Corvettes with FI.
          • 15657
          63-65 FI also use different wires. They have 90 degree connectors/boots on the distributor end. The short cap and 90 degree boots are necessary to get everyting to fit under the shielding.
          • Jerry S.
            • May 31, 2003
            • 145
            Thanks for the help, I found an Olds parts house with a cap in stock. $13.99
            • William C.
              • May 31, 1975
              • 6037
              Watch out that it is not a current production item, they don't judge well.
              Bill Clupper #618
              • Jerry S.
                • May 31, 2003
                • 145
                Thank you for your interest. Life is too short to have someone tell me what is incorrect with my beautiful car. Let me be the judge and I will never make an enemy. An example is a friend of mine judged the engine and chassis of a mid year car that had early parts and were told my the head judge to over look these minor items.
                • David H.
                  • December 1, 1996
                  • 241
                  Do they still have the shorter caps and 90/0 boots if the car has no radio? or just cap, or just wires? please respond. David
                  • William C.
                    • May 31, 1975
                    • 6037
                    Yes, same cap and wires for FI with/without radio.
                    Bill Clupper #618
