C2 Rear Spring Rebuild/Replacement - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2657
    The ride height of my '64 convertible is showing sign of sagging. I'm looking into either having my original std. 9-leaf rear spring(s) re-arched or just replacing the assembly with a new one from CC, Zip or Paragon. My questions are; 1.) Has anyone had their original spring re-ached/restored? If so, who would you reccommend to do the work and what is a ball park price? 2.) Has any one had good or bad experiences going with a current replacement part? The car will not be flighr judged again, but I'd like it to still look correct, i.e. the gray finish, etc.
    Any comments would be greatly appreciated.
    James West
    Omaha, NE.
    NCRS #18379
    1964 Corvette convertible #9258
  • Mike M.
    • May 31, 1974
    • 8389
    Re: C2 Rear Spring Rebuild/Replacement
    i've had about a dozen sets of c-1 and a dozen or so c-2 rear springs re-arched for vettes destined for judging. shop here in town closed about a year ago but to rearch a midyear spring, it used to cost about 25.oo.The downside of rearching(cold method) is that the spring will re-sag quicker than it did before re-artching. If you vet is a driver, go with aftermarket NEW spring assembly.mike
    • James W.
      • December 1, 1990
      • 2657
      Mike,
      On a "normal" mid-year rear spring, should the be a slight arch from the center (high point of the arch) out to the trailing arms (low point of the arch) or should id be more or less level with the normal static weight of the car? My spring is level from end to end.
      James West
      • Mike M.
        • May 31, 1974
        • 8389
        they were arched before the sagging process got to the point it is now(horizontal).driving a midyear with a horizontal (sagged) rear spring will eventually cause the differential output flanges to eat away at the case of the 3rd member.mike
        • James W.
          • December 1, 1990
          • 2657
          Causing the failure of what? Side yoke bearings, ring gear & pinion?????
          James West
            • 15677
            The number one cause of lost rear ride height is compressed spring link cushions. The set of four costs about ten bucks and takes an hour to change.
            Before you condemn/remove/modify the spring, replace the spring link cushions.
            • James W.
              • December 1, 1990
              • 2657
              Duke,
              Any change in ride confort by going to a polyurathane bushing which should be less likely to compress like the rubber ones?
              • Mike M.
                • May 31, 1974
                • 8389
                Duke: agree cushion failure is #1 cause of low sitting c-2 and 3's BUT their distortion with time wouldn't directly cause the rear spring to assume a horizontal position.Been my impression that horizontal springs have worn and re-arching is one temporary fix. regards and thanks for the tire answers the other day. Ole Farm Use now has 4 Kumho V700's for booties and is itching to go after the kraut-mobiles.mike
                  • 15677
                  Stick with the rubber cushions. In fact, new one will considerably REDUCE ride harshness. Old compressed cushions cause high rear suspension ride harshness.
                  I consider them a normal maintenance item. They should be replaced ever 5 to 8 years.
                  • James W.
                    • December 1, 1990
                    • 2657
                    Duke,
                    Periodic replacement makes sense. I rebuilt the rear differential, rear suspension and religned my origanal spring about 12 years ago. Guess it's time to replace the cushions and have the car re-aligned again.
                    Thanks to both you and Mike for the feedback.
                    Also excellent info in the tire articles in the Restorer. I'm planning a tire upgrade next spring and your articles answered some questions I had.
                    Best Regards,
                    James West
                    Omaha, NE.
