1960 Valve Covers - NCRS Discussion Boards
1960 Valve Covers
  • Joe Maulsby
    1960 Valve Covers
    I purchased a pair of steel valve covers at a junk yard. The two temp. wire clips/brackets are tack welded onto the side of the driver side cover. Is this the correct placement of Corvette clips? Or are the clips suppose to mount under the valve cover philips head screws?
  • John M.
    • January 1, 1999
    • 1553
    Re: 1960 Valve Covers
    Joe,
    The clips are indeed supposed to be welded to the side of the cover. You do know that there is a difference between Corvette covers and passenger covers don't you? The passenger car covers have sloped ends while the Corvette covers ends are straight up and down. It is getting tough to find a set of Corvette style covers in the junkyards, and if you got a nice set, then you made a good find!
    Regards, John McGraw
