68 Radiator Shroud attaching bracket - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    Gentlemen,
    Yet another radiator related question:
    My 68 has the copper radiator and Air Conditioning. I have the correct fiberglass reinforced plastic shroud with the extensions.
    The top of the shroud mounts to the radiatorsupport via a bracket that is welded to the support and has two (2) mounting holes. The bracket that I have has two holes that match up to the radiator support HOWEVER the opposite end of the bracket whihc attaches to the shroud also has TWO (2) holes and the shroud only has ONE (1) hole. I have looked in the aftermarket catalogs that I have and it has not helped. The AIM confuses me as the radiator set up shown for the c-60 air conditioning (whihc I have) seems to be similar to the 427 motor and I have the small block L79 (327 with 350 Horsepower).
    Do I have an incorrect bracket and if the answer is "YES" where can I find the correct bracket?
    Does anyone have the same motor as I have with A/C that would be willing to send a picture via e-mail.
    Thank you,
    Kurt Butning #26406
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 68 Radiator Shroud attaching bracket
    Only one hole in the bracked is used. The LH one. I have pics.
    • roy braatz
      My all original 68 mouse is the same using ONE hole and the other is not used , must be for those RATS
      • George Daina
        You are so.......
        correct in your assessment....two holes for the rats.....yea....long live the rats...
        • Kurt B.
          • July 31, 1996
          • 971
          Can I assume therefore
          that the bracket I have with the two holes is in fact the correct bracket?
          Thanks all,
          Kurt
          • George Daina
            Yup........ *NM*
            • roy braatz
              Re: You Rat-Rascals *NM*
