I'm sure this has been asked before, but I'm having trouble finding it in the archives.
I have a 70 LT-1 Roadster with manual steering on new 225/60-16 tires on new 16" rallyes. The car is a nice-weather-only driver, and sometimes I like to have fun cornering. I REALLY dislike oversteer though.
In the recent Restorer article on performance tires, it suggests changes to the alignment specs for better handling. I would think there might also be changes to accomodate radial tires over the bias tires of the era.
Service Manual calls for:
Spec Front Rear
Toe 3/16 to 5/16 1/32 to 3/32(per wheel)
Caster pos 1 +- .5deg
Camber pos3/4 +/- .5deg neg7/8 +/- .5deg
From the suggestions in the Restorer article, I'd get:
Spec Front Rear
Toe 1/16 1/16(per wheel??)
Caster pos 1.5deg
Camber neg 1/2 +/- .5deg neg 1.0 +/- ?
Am I interperting this right? Is the rear Toe "per wheel"? Are there any other changes you'd suggest?
Kevin
Spec Front Rear
Spec Front Rear
Caster pos 1.5deg
Kevin
