Radiator Seals 1968 Corvette - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    Gentlemen,
    On a 1968 with A/C, (I don't know if it matters) do the radiator seals go between the raidator and the radiator support OR between the radiator and the shroud?
    Thank you,
    Kurt # 26406
    • 11651
    Re: Radiator Seals 1968 Corvette
    Kurt,
    "Assuming" that Doc Rebuild is correct, and that my 71 is the same, the answer is "both."
    See link below.
    Patrick
    seals at doc rebuild
    • Larry E. Howard
      Kurt,
      There are seals between the radiator and radiator support and there are also seals between the shroud and the radiator. The first is called the radiator support seal the latter is the shroud seal. The term "Radiator seals" can mean either. Check your assembly manual or a good Corvette parts datalog for photos.
      Larry
