C1 dash insert - NCRS Discussion Boards
C1 dash insert
  • richard raine
    C1 dash insert
    I am looking for the stainless trim pieces for my 1960. It seems no one makes them. Can anyone direct me to a source?
    Also, in case I have to make one, can anyone tell me how wide the visible tim is and what thickness the steel is?
    Richard
  • Ed Jennings
    Re: C1 dash insert
    These will be a little tough to come by. As far as I know they are not reproduced. There are any number of vendors who will likely have a complete restored assy in stock, but I suspect it will be pricey. Check with Mary Jo Rohner and Chicago Corvette. They are both pretty apt to have pieces like this, but hang on to your wallet if they do. Might also check with Cranes.
    • Larry E. Howard
      Re: C1 dash insert
      Richard,
      Ed gives good advice, shenever I exhausted my normal sources, ebay,CC, and Zip Products. I went to mary jo and she always had what I needed. But due to her prices it was usuall the last place I went. I completed my 57 two years ago so I haven't done business since then. Ph 858-451-1933 or her website is "vettegal.com" Tell her Larry from Tennessee sent you!
      • Karl #35089
        Re: C1 dash insert
        sometimes complete insert assemblies with main panels in bad shape go for (relatively) cheap on ebay. good for salvaging trim parts... -k
        • Ed Jennings
          Re: C1 dash insert
          That would be the forst place I'd look.
          • Ed Jennings
            Addendum
            BTW, you asked about dimensions to make some parts. If you get to that point, I'll be glad to get you some measurements, but IMHO, unless you have some very fancy metal forming equipment these parts would be very, very tough to make.
            • Mark Gustetter
              Re: C1 dash insert
              Richard,
              If all else fails, try calling "Patty" at Corvette Central (800.345.4122). For $154.00 + s/h they will send you a completely refurbished dash insert assembly, including the upper and lower stainless steel trim. I'm about to do the same on my '59. Good luck.
              Mark R. Gustetter, AIA
              • Joe Maulsby
                Re: C1 dash insert trim
                I purchased one from Paragon Vintage Department last fall. It was pricey (forgot exact amount), but it was in good condition.
