Due to frustration, I have pulled the Carter WCFB and purchased a replacement carburetor, rebuilt by Holley, a Rochester 4GC. I know it is incorrect, but I thought it would give me a good runner while the original is being restored.
However, once hooked up, it allows for a quick start up but won't idle at anything less than 1500 RPM. Obviously I have a problem. I have replaced all vacuum hoses and haven't touched the adjustments from what was set by Holley.
The idle adjustment screw doesn't even come in contact with the choke piece. Could it be in the choke and throttle rods? Is this just an example of a bad rebuild by Holley or is there an adjustment I need to make.
I appreciate any ideas and maybe the best is to take it back to the shop I bought it from....
