Replacement Carburator for 1965 365hp - NCRS Discussion Boards
  • Peter P.
    Infrequent User
    • January 1, 1988
    • 6
    I would like to know of any reputable suppliers that would be able to help me secure a rebuilt or "new" carburator for my 327/365 HP 1965 vette. Date code is not as important as functionality. Any recommendations out there? Thanx.
  • Brian Monticello
    Re: Replacement Carburator for 1965 365hp
    Pete,
    I'm in the same boat but have limited my self to a 2818 (date not important). Have you looked at the holley 3367 from 1966 or the 3810 from 1967? I missed a NOS 2818 that sold for $280. I've heard the 3811 will work too.
    I've also heard that your run of the mill 1850 with proper jetting is a suitable replacement and there are tons of them out there.
    There is what appears to be a new 3367 on Ebay for $350. I have no idea what "new" means in this case. Holley still sells the 3367 as part of their O.E. muscle car line.
    I've never even owned a holley so read with caution! I'm sure some others will weigh in.
    Brian
    • Joe C.
      • August 31, 1999
      • 4598
      Pete:
      Any Holley 585 CFM model 4600 will work. Just be sure to install 122-65 primary main jets, and 122-72 secondaries, with a 065 power valve. Go to www.holley.com to check the specs.
      If you want to spend the big bucks for a model 2818, then try Jerry Luck. He might have an improperly dated service replacement carb in inventory that he can prepare for you.
      Joe
      • Jack Layton
        Buy this one and rebuild it ! Or wait on e-bay for a better one with the choke and all intact.
        Are you aware of how to decode the date on these carbs ?
        • Peter P.
          Infrequent User
          • January 1, 1988
          • 6
          Thanks, new to the Carb situation. Went to the Holley web site, saw a 600 CFM/ model 4160 and 585 CFM / model 3367, not familiar with 4600 - also - additional rookie question: mechanical or vacuum secondary?
          • Clem Z.
            • January 1, 2006
            • 9427
            3367 is a carb for a 1966 327 300/350 HP with a remote choke. i would guess that it should work fine on other year corvettes with the same engine.
            • Peter P.
              Infrequent User
              • January 1, 1988
              • 6
              Hi, can you help me with how to contact Jerry Luck?
              • Clem Z.
                • January 1, 2006
                • 9427
                if you have no luck with luck try craig woodruff at 330-799-9479.
                • Mark G.
                  • March 1, 2001
                  • 227
