engine identification - NCRS Discussion Boards
  • dale orris
    I need help in identifying a replacement engine in a 1965 corvette.
    It is a small block with the following on the block stamp pad. CE9473 74.
    thanks for all replies..
    dale orris
  • Mike M.
    • May 31, 1974
    • 8396
    Re: engine identification
    CE stamped engines are over the counter engines. what you'll need to do is look at the left rear engine case flange(what the bellhousing bolts to) and post the casting # you'll find there. also helpful to post the cast ing date. mike
    • dale orris
      Thanks Mike. I know now I should have gotten the casting number also. I will post as soon I can get the numbers. thanks for the help and reply.
      dale
        Dale -
        All you can tell from the pad stamp is that it's a "CE" warranty replacement short block assembled in 1969. These assemblies were ordered by specific part number to match the internal configuration of the failed engine, but that part number doesn't appear anywhere on the replacement engine. No way to determine the nature of the innards without tearing it down.
