Proper heater hose routing 71 350 w/air - NCRS Discussion Boards
  • PaulH
    The heater hose running from the shut-off-valve to the intake manifold currently is routed over the compressor. I noticed in the build manual that it should run through a clip on the fender, under the compressor, through a bracket under/on the compressor and then it routes up to the intake. I tried this routing but the hose kinks where it connets to the intake manifold fitting...the bend is too sharp. Is the book correct? If yes how can I mount without the kinking problem. Any help of photos are appreciated. bronyaur@att.net
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Proper heater hose routing 71 350 w/air
    Paul I have bought A/C heater hose that has a slight bend molded into the hose at the intake end but I don't know the vendor. Lyle
    Lyle
    • Harmon C.
      • August 31, 1994
      • 3228
      Re: Addendum
      Paul The hose routing you described sounds correct and I may have bought the hose from Parogon. I do not know if original hoses had the molded bend but I think it will solve the problem you are having. Lyle
      Lyle
      • Gerard Q.
        • February 1, 2000
        • 284
        Paul You Have Mail *NM*
