56 powerglide shifting problem - NCRS Discussion Boards
  • jim schultz
    I have a recently rebuilt 56 cast iron powerglide that shifts very hard. It shifts into high gear very harshly, with a decided clunk. Is there any adjustment for this, or does it have to come out? Is there any documentation on rebuilding these things?
  • William C.
    • May 31, 1975
    • 6037
    Re: 56 powerglide shifting problem
    There is some adjustment, the TV linkage and also the vacuum modulator both affect the shift. I would look first at the vacuum modulator, and or the vacuum hookup to the modulator for a "too hard" shift.
    Bill Clupper #618
    • roy braatz
      Bill -Jims 56 PG dosen't have a modulator, he wrote me and I told him to ajust the low band and linkage.That most likly is his trouble.
      • roy braatz
        Re: 56 powerglide bad news
        Schultz Poor guy E-mailed me after I told him how to adjust his trans shifting problem and realized he has to remove it now to correct it. Who ever rebuilt it srewed up.There is nothing simpler then a PG cast or alum. to rebuild.If any one can remove one from a Corvette , then you can rebuild it. A kit is around $100.00 and a shop doing it can run around $2000.00 and up. If any one can use help I'm willing to try and help you. ROY
