Paint On The Engine Pad - Safe Way To Remove? - NCRS Discussion Boards
  • Jace H.
    • April 1, 1997
    • 253
    Help, my motor guy accidently got some paint on my engine pad. What is the safest method to remove without damaging the broach marks.
    Jace Holt
    Re: Paint On The Engine Pad - Safe Way To Remove?
    Jace -
    Lacquer thinner on a rag - don't use anything abrasive.
      • 43222
      Jace-----
      Use a solvent which will disolve the dried paint or use paint remover. Glycol brake fluid might work well, too. Don't use anything abrasive; you shouldn't have to anyway. Don't worry if some of the paint remains in the stamped characters; that's how it usually was on the original engines---the engines were painted and the wet paint wiped off the stamp pad. So, paint often remained in the stamped characters.
