c2 tri power ? - NCRS Discussion Boards
c2 tri power ?
  • rich heimbrod
    c2 tri power ?
    after resoring my 67 , i'm going to drive it this summer with a fresh 396. Can i put my rectangle intake on the oval port heads? Are there any special gaskets for this? Years ago i turned my 427 into a drag engine 121/2 to 1 I have never started it since.Thanks again Rich
  • Jerry Clark
    Re: c2 tri power ?
    Rich:
    I've done it. Although it will obviously not be the hot setup from a performance standpoint it will work quite well. Use the standard rectangular port 435 gaskets.
    jer
    • Jerry Clark
      Addendum
      I have installed 435 intakes on 400/390 hp engines. There is no fit problems typical to this installation but you might provide more fuel than a low horse 396 may handle, a 360 hp 396 would probably work or any 396 with cam and ignition that can fire the mixture.
      jer
      • rich heimbrod
        Re: Addendum
        thanks Jerry, I'm using a402350hp right now until i get the 427 ready.Also do know if using open chamber heads on my closed chamber427 could it lower my comp.? my 427 is 121/2 to 1 30 over, if not i'll probly have to change pistons again. Thanks again Rich
        • Clem Z.
          • January 1, 2006
          • 9427
          comp ratio
          go to www.bgsoflex.com/auto.html and plug in the numbers.
          • Jerry Clark
            I KNEW You'd
            answer that one
            • Clem Z.
              • January 1, 2006
              • 9427
              Re: Addendum
              if you do not know the ccs of the heads and pistons post the casting/part numbers and i will see if i can help
