c2 wiper blades - NCRS Discussion Boards
c2 wiper blades
  • rich heimbrod
    c2 wiper blades
    I'm restoring my 67 after 25 yrs.after it had sat all apart. the pass. side is longer by 2 inches, is this correct? also which blade goes the closest to the windshield? Thanks Rich
  • Jerry Clark
    Re: c2 wiper blades
    both are the same lenght. If you are referring to which wiper lies on the windshield trim, (lowest), it is the drivers side
    jer
    • rich heimbrod
      Re: c2 wiper blades
      Thanks Rich
      • Peter L.
        • May 31, 1983
        • 1930
        Re: c2 wiper blades
        Rich - Both holders should be 15". Both ANCO and TRICO holders with a peaked shape top configuration were used throughout the production year. Wiper blade assemblies (holder and rubber wiper insert) were installed in production so ANCO holders used ANCO rubber wiper inserts and TRICO holders used TRICO rubber wiper inserts. Pete
        • Mark G.
          • March 1, 2001
          • 227
          • Peter L.
            • May 31, 1983
            • 1930
            Re: c2 wiper blades
            Mark - The set up as described for the wiper arms sounds as I would expect for an early '66 car. The Corvette Restorer, Vol 27, No.3, Winter 2001, p. 12 shows the configuration of the ANCO wiper blades. Check it out for the ANCO windshield wiper blade configuration. But, if you don't have the "red button" holders, you probably have the "original" ones. Pete
            • Mark G.
              • March 1, 2001
              • 227
              Thanks Peter, I will check my files. *NM*
