1963 Alternator search - NCRS Discussion Boards
  • Jerry S.
    • May 31, 2003
    • 145
    My 63 coupe has the following numbers; 1100668-37A 4E14-12V NEG. I have been told that the alternator should be dated _A_ for January. Any suggestion on how to locate a 40 year old alternator. Was this alternator used on other GM bodies? This would help with the search.
  • mikemccagh
    Re: 1963 Alternator search
    John Pirkle who advertises in driveline should be able to get you going. mike
    • Jerry S.
      • May 31, 2003
      • 145
      I have been told to look for Alternator 1100628 as this was used in 1963. One of the books I read said something about a Feb 1, 1963 alternator change. I wonder if this information is correct since my car was assembled Feb 13, 1963?
      • Jerry S.
        • May 31, 2003
        • 145
        I located the correct alternator and the problem is solved. Thanks for your help John in Georgia had one.
          • 15676
          Since the alternator was a St. Louis installed item, this is a case where you can
          research original source facts in your AIM, particularly the engineering change record. In
          this case, the EC record begins with symbol "5" on 3-5-63, so the earlier changes are
          lost, but according the the NCRS Spec Guide the 628 was used on all configurations
          except C60, and there is no indication in the C60 section of any alternator other than
          1100633, but there was a pulley change and the air cleaner base was different, which
          may be related to the pulley change.
