'72 Tach Cable - NCRS Discussion Boards
'72 Tach Cable
  • Al S.
    • June 30, 2002
    • 73
    '72 Tach Cable
    Looks like I'm going to have to replace my tach cable. I understand that most of the replacements are too long. Has anyone found one vendor over another closer to the original length, or are they all a problem? I've disconnected it from the distributor and pulled on it then re-connected it. It works for a while then quits again. Looks like the tip in the distributor end may have broken off but I don't see the other piece in the distributor. The cable now appears too short and worms it's way back towards the tach and quits after a few minutes of running. Any input is appreciated as always.
    '72 Top Flight Coupe
  • G B.
    • December 1, 1974
    • 1407
    Re: '72 Tach Cable
    All I found for sale had housings that were too long to fit properly.
    I would buy a speedometer cable repair kit at an auto parts store and cut it to length. In other words, re-use your old tach cable outer housing.
    • Ed Jennings
      Re: '72 Tach Cable
      Better yet, go to a speedometer shop and have them make you a cable to fit with regular swaged ends. I've never had much luck with those cut to fit things.
