C2 antenna removal - NCRS Discussion Boards
C2 antenna removal
  • Eugene B.
    • May 31, 1988
    • 710
    C2 antenna removal
    Members,
    Tried unsuccessfully to remove the power antenna from my '65 this afternoon. The under body bolts came out OK, but trying to remove the bezel from around the antenna mast was a failure. It seems to have become one with whatever it is screwed into. (The antenna box, I assume). Any good tips for my next session?
    Gene
  • Jerry Clark
    Re: C2 antenna removal
    Gene:
    These can be a particular PITA. If soaking it with some good penetrating oil fails to loosen it then cutting it off may prove your only solution. A moto tool with cutoff wheel is easy to control in this area.
    Good luck
    jer
