Ignition Shielding - NCRS Discussion Boards
Ignition Shielding
  • Edward D. Reich
    Ignition Shielding
    I have a dist. - coil shielding for a Corvette and trying to find out the year.
    It has two small slots that say CARB - FI On the other side there is some sort of spring clip. The inner plastic shield is held by THREE metal rivits. I also have one that has TWO plastic rivits. Can someone out there help me out.
    Ed Reich. (Solid Axle).
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Ignition Shielding
    I believe the metal rivits are for a 63. The plastic may be for a 64 - 65.
    • William C.
      • May 31, 1975
      • 6037
      Actually, 64-67 used two rivits, but there are differences between 64-5 and 66-7 on the depth of te curve at the front of the shield to accomodate the difference between the air filters used in '66-7 as compared to the '64-5 style.
      Bill Clupper #618
