Tank sticker/build sheet - NCRS Discussion Boards
  • Eugene B.
    • May 31, 1988
    • 710
    Members,
    I just read an interesting piece of Corvette trivia from my local chapter (Ohio) of the NCRS. They state that "The '67 model was the first to have the "tank sticker", or build sheet, attached to the gas tank." Is this correct information? I thought that this procedure started long before '67. If they are correct, where were the build sheets (or were there any) on midyears prior to 1967?
    Gene
  • Craig S.
    • June 30, 1997
    • 2471
    Re: Tank sticker/build sheet
    Gene - that is true, 67 was the first year for build sheets on the tank. As far as I know, prior to that there was no history, at least that was with the vehicle when it left the plant, per any of the documentation classes I have taken from Al Grenning. Maybe the line used it, but discarded upon completion of assembly...Craig
    • Eugene B.
      • May 31, 1988
      • 710
      Craig,
      Thank you for your response.
      Gene
